1996 Mercruiser 3.0 Broken Starter Bolt
Stevie13ray
Not a professional so my terminology may be off. I've drilled out most of the old bolt that sheared off in the block. Pretty sure I messed up the threads. My question is, what size tap would I need to rethread the hole? Prefer one with a hex shank to go into a 90? drill attachment.
alldodge
Bolts are (3/8) .375-16 thread. get a 3/8 helicoil repair kit. The kit will contain the drill, tap and helicoil. Drill should be 25/64
G_Hipster
Tapping cast iron can be peculiar. I would not attempt to run the tap by a drill motor if that's the intention. It's a pretty good way to break the tap in the hole.
I would take the hour (or less) and pull the motor, put on the stand, flip upside down, remove the pan for clearance and then deal with the broken bolt
that way you can also find out why you broke the bolt in the first place.
kenny nunez
2xs on what Scott is telling you. The only other thing to check is that the bolts are not metric.
Alumarine
If you have the standard old style heavy starter you need a support bracket from the front of the starter to the block.
If so, it might be a good time to swap it out to the smaller style.
my guess is a hydro-lock event lead to the broken starter bolt
