Hello
I have a 1996 Johnson 9.9 that needs a new water impeller. I was able to remove the 6 bolts holding the lower unit on, and it then dropped about an inch, but the shift linkage is still connected so it can't be removed. There isn't a traditional "two screw" link that I can remove like I have seen on older motors.
Does anyone know how to disconnect the shift linkage so I can remove the lower unit?
I believe the model number is J10FREDR
The serial number is 04157875
