I was given a 1996 Johnson 15 it has no spark "J15 rleds" I am a rookie where do I start?
S Shermaneddy Recruit Joined Jul 24, 2017 Messages 1 Jul 26, 2017 #1 I was given a 1996 Johnson 15 it has no spark "J15 rleds" I am a rookie where do I start?
D desertratz Seaman Apprentice Joined Jul 16, 2017 Messages 49 Jul 26, 2017 #2 if you have a multimeter ohm out the coil, and check the spark plug. start there.
flyingscott Fleet Admiral Joined Apr 8, 2014 Messages 7,994 Jul 26, 2017 #3 Remote or tiller model? Did you get the tether for the safety switch with it? If you did is it on?
1 175se Petty Officer 1st Class Joined Mar 6, 2014 Messages 274 Jul 26, 2017 #4 I myself would look on the port side of the motor for a single rubber connector (black wire yellow tracer) unplug it see if t has spark. Just finished one with same issue, defective kill switch.
