i had my motor worked on and now my trim gauge doesn't work and my manual is no help. The sensor has to be at the pivot point on the motor. Does any one have a pdf or a picture of what it looks like or any other help. Thanks
The sender is black with a hinged arm and is mounted on the inside of the port transom bracket.
If you go to the BRP parts catalog for your motor and look at the "midsection" diagram you can see how it is set up.
