1996 force 50 Wiring Diagram...Anyone have one?
smoedog
I need a 1996 force 50 Wiring Diagram. My boat has a 1996 force 50 and I am going to be putting on an early 80's johnson 90. My boat has a 7 pin ( i think, need to confirm) connector. Just trying to get a map or where I need to go.
Jiggz
No Title
Note item #13 which is the engine wiring harness with 7 pins. Hopefully this matches your motor. You might want to save and print the diagram to make it easier to work with. Enlarge it if you need to.
jerryjerry05
The Force/Mercury harness is color coded.
So is the Johnson.
The controls and wiring won't swap.
smoedog
What do you mean jerry about the wiring won't swap? I get that the force harness won't connect to the johnson, But is the color coding the same?
