Had the boat out this morning, first time this season. Last season I replaced the impeller/housing. Today at headway speed the temp just started to come up, but at running speed the temp dropped down right off the gauge.
Water temp was 50 degrees F.
I'm thinking I should check thermostat but have read here that some V4 thermostats are very difficult to service. I have the shop manual which makes it look pretty easy except it says that the thermostat should be serviced when the powerhead is removed.
Can I do the thermostat with the powerhead in place on this engine? Is it difficult?
