snake91876
- Jun 25, 2007
- 211
I am familiar with most motors being 1 1/2 out but rebuilt carbs on 95 50hp and didnt count the turns. Motor will not even run unless i continuously press the primer button on key. Also the plastic covers on side of carb are warped but look like they are sealing could this be a problem. Will run from primer but will not run off carbs. HELP! Oh i got good blue spark and 140lbs compression both cylinders, Vro is still hooked up and carb bowls are staying full of gas.
