Hi, my 1995 15 hp Johnson has a high speed miss on the top cylinder, I think. The boat runs fine at low speeds, but will miss off and on every few seconds at high speeds. Backing off on the throttle will actually make the motor run a bit better, but nothing like what it did years ago.
If I stop the engine and check the plugs, the top one is always wetter, the bottom grey and dry. I have switched coils by reversing coil and spark leads, still the top cylinder. I have done a warm compression test: 102 psi top, 100 psi bottom. I have checked spark gap by hand cranking: 1/2 inch blue/white spark on both cylinders. I have removed power pack and coil assembly and cleaned all grounding terminals. Head temperature seems fine, I can touch it for about 2 seconds, then ouch. Problem is there when warm or cold, but does seem to get a bit worse after about 20 seconds of running. I have tried: carb rebuild kit, fuel pump rebuild kit, new fuel line and tank, decarbed with sea foam three times (concentrated mixture), new plugs, and a new top seal. Nothing seems to help and the problem seems to have slowly gotten worse over the last year.
I think my next step is to buy a new power pack, unless someone has a better idea?
Thanks for all the great infromation I've found here.
-Chris in NW Ontario
