1995 115 not charging
aid1970
hopefully someone can help. i get 40 volts plus ac out of the 2 yellow wires that go to the rectifier but its not charging the rev counter works. any help is greatly received. thanks.
Vic.S
Re: 1995 115 not charging
Id say almost certainly the rectifier. Check the DC volts at the red output wire. if it stays at battery volts then pretty much confirms it.
Any chance you connected the battery with reversed polarity ... that's instant death to a rectifier
The simple non regulated rectifiers are easy to test but the combined regulator and rectifier not so
aid1970
no defo not connected wrong way is that voltage ok on the ac side ?? where do i get a new rectifier from?? how do i test it ??
aid1970
battery volts stay the same at red wire. does anybody know what readings i should get from the other wires or how to test them ????. thanks in advance
ezeke
Put an AC voltage tester on the gray tach wire; it should read at least 5 volts AC with the engine at fast idle.
Put the DC voltmeter on the battery; it should read higher with the engine running at fast idle than with it off.
Other checks here: http://cdielectronics.com/InstallSheet/193-4204.pdf
Vic.S
You have not filled in anything for your location in your profile so have no idea whereabouts in the world you are
I get my stuff from Outboards direct but iBoats would be a good choice if you are in the USA.
I think if your tachometer is working you will almost certainly get the correct reading on the gray wire
aid1970
Thanks for that. the grey tach wire goes to one of the yellow wires if i mesure the voltage between the 2 i get from 40v upwards depending on the revs. should i go between the grey and earth?
ezeke
Gray to engine ground. If you put external voltage on the gray wire you will need a new rectifier for sure.
aid1970
does anyone know if or how they could be repaired. i know someone good with electronics.:)
aid1970
another question where is the full throttle timing adjustment on this engine ?:)
