Hello,
Just installed new long block in my proline, got it running and had question about timing. This is a fuel injected motor and I know the timing adjusts itself while underway. Do i need to time this motor with a light after the first startup or does it adjust itself? If i do need to time it it says it should be at 8 degrees for base timing, is there a wire or something i need to disconect? The setup is a 94 Volvo Penta 5.7 GI PMDA. If anybody has the link to the shop manual i can prob look it up myself.
Thank you in advanced.
Chad
Chad
