1994 Suzuki DT40C Cooling problem
Gator429
Hi,
Subject outboard (2 Cyl - 2 stroke) not used much in past 3 years. Not cranked in past 12 months. Runs fine, but not cooling properly. Changed water pump impeller & gaskets. Also put in new thermostat. Checked all water outlets with compressed air; found no plugged outlets. When running, water comes out pilot discharge hole (pee-hole). However, no water comes out water overflow outlet (rear of shaft housing) or the Prop water outlet as it should. Impeller was installed with vanes pointing in correct direction.:confused:
Thanks.
99yam40
Re: 1994 Suzuki DT40C Cooling problem
Sounds like you will need pull head and to check for blockage in passages
