My 1993 Mercruiser 3.0L is running really well, but the motor has developed a knocking noise. Oil pressure stays constant at 20-30 psi on the gauge depending on throttle, and I haven't noticed any loss of power. The noise speeds up and is correlated to the amount of throttle applied. Sounds like it's coming from the bottom of the engine, near the crankshaft. I just replaced the harmonic balancer because it had run out. Next time I get to the boat I'll do a compression test and pull the plugs one-by-one to see if the noise changes. Do you more experienced ears have a good idea of what this is? Link to the video is below. Thanks!
https://youtu.be/X-OXukaqj6Q
