I have removed one of the hubs, bearings, seals, etc. and the axle is tapered. I took measurement with a tape and 'eyeballed it' best I could. I read the sticky at the top and it showed part numbers on the bearings, but I can't see any on mine?
Inside bearing inner diam 1.5"
Outside bearing inner diam 1.25"
The inside hub inner diam 2.25"
Outside hub inner diam 2"
Does this sound right? My local parts stores (limited/small town) aren't showing these sizes.
The one I took off was slinging grease on the inside, so the seal was shot.
I'm going to do the other side also because it was fairly hot to the touch the last few times I took it out.
