1993 Big Jon Lowe Complete conversion
Bob_VT
Re: 1993 Big Jon Lowe Complete conversion
Nice job.....what did you use for plywood? What did you coat it with?
Welcome to iboats.
jigngrub
That wood looks kinda pressure treated?
Alaskanhawg
I used pressure treated wood with a coat of fiberglass resin on it.
Woodonglass
Uhmm.. Polyester resin without Mat is not optimum for sealing the wood. It will cure very hard and brittle an when he wood flexes, which it will the resin will crack and this will allow water penetration. It will also alow the chemicals in the PT plywood to leach out onto the aluminum hull and this is a bad thing. The chemicals have an adverse effect on aluminum and will start a chemical process that will severely corrode your hull. Lot's of info about all of this here on the forum if you do an advanced search on the topic of Pressure Treated plywood.
