rustybeater
- Jun 26, 2011
- 48
I have a 1993 90hp Johnson V4. About two weeks ago I just put in the water idled fine away from the ramp, but when I went to give it throttle she started to get on a plane and then died after this she would not take any throttle at all without dying. The motor was even wanting to die out trying to idle back to the ramp I did find out that when she started to die out if i pumped the primer it would stay running. Once I got it back home, I went ahead and rebuilt the carbs (I have been meaning to do this for some time now anyway) and I replaced my fuel filter. I took it back on the water and i noticed that the boat was slower to get on a plane and later on in the day the motor started not wanting to take any throttle again. I was able to pump the primer a couple of times while it was wanting to die at idle then it started to idle fine and i was able to get back on a plane but it was still slower than before. I used to have a top speed of 38 mph and this time I could only get to 35 mph. I went back home and borrowed a compression test set this is my fist time doing this and I did it the next morning when the motor was cold ( I later read on this site that it says to warm it up first I am not sure if it makes a difference) Top Left = 92, Bottom Left=93, Top Right=98, Bottom Right=74. Obviously, I am concerned with the number I am getting from the Bottom Right cylinder. I am not sure if the fuel problem is related to the compression. I am newer to boats and I am trying to figure out what direction I should go with this.
