1993 175 evinrude key switch
RuGbyPrOp
need diagram 4 key switch,re wired boat and lost power to fuel pump,tach,volt meter help!
Joe Reeves
Re: 1993 175 evinrude key switch
I don't have the diagram but I'm wondering if you may have blown the inline power fuse that is located in one of the smaller RED wires leading from the starter solenoid.
Chris1956
The purple wire should supply the gauges with power. See if it has voltage on it. If not check the red/purple wire for voltage. If no voltage there, check fuse between red wire and red/purple wire.
Faztbullet
Could be missing ground to gauges also.....
