Newtonsean
- Apr 18, 2016
- 10
This maybe a long shot but I am troubleshooting a NS70A2 on a boat I recently aquired and I have narrowed it down to either the carbs or the fuel pump (probably not the right term forgive me) that is on the side of the motor. I'm going to try bypassing the pump and letting it gravity feed to see if that's the issue if not I'm going to rebuild the carbs. 2 things I need advice on
1. I have searched high and low but can't find a carb kit
2. Is there anything else I should check before tearing the carbs apart
I can get it to fire and run while I am squirting seafoam directly into the carbs
