Re: 1992 Force 70HP powerhead exchange
If I remember correctly, the 70 Force was a "bastard" engine, completely different than any other three cylinder engine except the 75. While any three cylinder block will bolt onto the leg, the 70 and 75 had a single carb and a special boss to mount the shift linkage. Therefore I am relatively sure that only these two engine blocks will swap--not 100% certain, and maybe someone else can either confirm or deny my opinion.
I have a 70 in my garage and have been toying with the idea of mounting a 90 block in it--just to see. There is room for the three carbs if I remove a baffle in the top shroud, and the drive shaft splines match the crank splines. I am trying to figure out what I need to do to mount the shift linkage--perhaps some metal massaging.
