Re: 1991 superfisherman rebuild
well, pressure washing is done for the day. I could not find any leaky rivets during the washing or after, but I did find a small pinhole on the starboard side reverse chine where it meets the transom. Once she dries out, I will have to give it a closer look.
Top mark is the hole, bottom spot is just a chip. Can I just throw a rivet in there, or should I use another method?
Is this corrosion?? If it is, how should I address it? Its only surface for now, would like to keep it that way.
this is the corner of the knee brace and the transom in the bilge. The small gap in the corner is where the water drains into the bilge from the outside stringer. As you can see, its not hard to get some crap in the drain channel and block flow. Could I enlarge the drain area a bit, or should I avoid because it is the knee brace?
A little cleaner after the pressure wash.
