1991 Johnson Faststrike 150 Fuel Problems
califragh
VRO alarm started to go off, I disconnected it ran premix but lost fuel delivery. boat would run fine as long as someone was in the back squeezing the fuel bulb. Rebuilt fuel pump new filter new hose new primer solenoid kit. Still same problem please help. on muffs mid throttle i feel fuel pump pulsing but for some reason it starves for fuel. going to rebuild the vapor pump next would that do it
boobie
Re: 1991 Johnson Faststrike 150 Fuel Problems
Sounds like the problem is in the fuel side of the VRO.
califragh
I rebuilt the fuel side VRO. There was some black tarring on part of the main spring which I cleaned, would there be an obvious defect to look for.
Faztbullet
Nope..... sounds like air motor in pump is not working or check valve diaphram is swollen ( half dollar size disk) and not passing fuel.
califragh
I have replaced the membrane in the vapor pump. Same problem keeps running out of gas, I am at my wits end. there is nothing else to rebuild. It has to be something stupid. Please help. Again i can keep it running if i keep pressing the primer bulb. It will run a full throttle no problem
boobie
You still got probs in the pump if you have to keep pumping the primer bulb.
califragh
Well, To heck with it. i am going to put in an in line fuel pump. What PSI should i get.
Thanks
boobie
If you're going to put in an electric one, that could be a fire hazard.
califragh
really hows that, just need a booster. the floats will stop flow. I may be an idiot thinking this way. Maybe use a 3-5 PSI. trying to go on the cheap to fix the problem. it is a 91 motor. Do not feel like sinking 350 for a new VRO Pump
boobie
If you had an accident and a fire started the pump could just keep on going if for some reason you couldn't shut the key off. But, that's JMO and your boat.
califragh
No thank you very much Guy, I value your opinion. I would not be here if i didn't. Thank you
I have a 96 175 faststrike. Fuel shoots out of the middle of the fuel pump when I pump the bulb. Will crank and run for 10 seconds and won't crank again for 30 minutes. After the 10 second run time there seems to be a lot of black liguid coming out of prop if i continuously try to crank it. What might this be and if primer bulb is tight should has be coming from middle of the fuel pump. Also vro has been disconnected for years and just running premix
zabortnick
I watched a boat Burn on the water last week and had to go to there aid. dont know the cause for sure but likely electical. so Be Safe and use caution before radicly modifying somthing or adding anything to the electrical. I would agree that your VRO is still the cause. they can be diff to reassemble the first time. its likely that you didnt get it right. have a diagram it helps alot.
califragh
A Follow up to my pump delima. I did use an in line pump. Have to be careful at idle can put to much pressure on the carbs. but at higher speeds it does the trick just fine. Used it in this matter for a while now. and boat flies across the water
