Bought this 91 johnson 40 hp for 200 dollars.
It had been burned up and both cylinder were scored. Removed the power head and took it to a machine
shop and bored the cylinders 20 thousand over size. Replace the pistons and rings, Reassembled and found the was a slight miss fire on lower cylinder.
Replace the old ignition setup with a new CDI upgrade. Finished it this morning. Been running it in a barrel for the most of the day.
Runs perfect so far.
Will be taking it to the Rideau river tomorrow.
cheers
cheers
