hey guys I am new here, let me start off by saying I am a car guy, restored a few classic cars in my time. just bought my first boat last month, 1991 bayliner classic 19' with 3 L I/O. I just finished recovering the upholstery, It was going great and was giving the boat a final clean before showing the wife, when i happen to take a better look in the ski storage. and found some rotten wood, well one thing lead to another and I pretty much have the whole deck ripped up. So I have 3 questions I need a Boat guy to help me with. 1) should I use pressure treated plywood to replace the deck? 2) All my foam under the deck was so water logged, should I be worried about a leak in the hull, I have not had the boat in water, but I inspected the bottom of the boat and it looks good, seeing that I ruined the old foam what can I replace it with, is there some kind of aftermarket marine sprayfoam? 3) upon futher inspection of the front motor mount (after pealing off the 1/2" plywood between the motor mount and the gas tank) I drilled four 1/4" test holes into the wood motor mount and it looks like only the first 1/2" of the motor mount is a bit soft, I was thinking of trying to chisel off the first 1/2" off the mount and replacing the original 1/2" plywood between the motor mount and the gas tank with a 1" board the make up for the 1/2" I removed from the motor mount. then refibreglassing the mount. any help or advise would be appreciated thanks
