dajohnson53
- Apr 28, 2004
- 1,627
J200TXESM. I connected the water pressure gauge tubing according to the teleflex instructions. It is T'd into the tube that feeds the telltale, about 2 inches upstream from the telltale itself.
I get 0 pressure on the gauge - idle, cruise, WOT, nothing. This is on the hose and in the water. I do get a strong steady stream out of the telltale.
I plugged the telltale with my finger while the engine was at high idle and the gauge then registered pressure. I was alone so I could only do this experiment from the back of the boat at idle and I couldn't read the exact pressure, but it definitely was registering good pressure at idle.
The telltale hose and the hose that feeds it (into which the pressure gauge tube is T'd) is quite a bit larger diameter than the pressure gauge tube.
Is this the problem? Do I need to reduce the diameter of the telltale tube to the same as the pressure gauge tubing in order for it to work, or is there some error I've made in the installation?
Thanks.
Thanks.
