cwburkeva
- Oct 12, 2016
- 39
After having this problem, I threw up my hands and took to the shop. Was told they figured out the problem. Now it is back. Here are the symptoms, any help would be appreciated:
1. Runs fine, starts, etc when cruising at around 2500-3000 RPM.
2. When increasing to 3500-4000 RPM for a sustained run, I get a hesitation/fuel cutout, then all of a sudden, engine just chokes out.
3. I can start it and it will idle fine, but when put into forward, I cannot increase throttle and it cuts out. I can restart several times, and eventually it won't start at all.
4. When cooled down (usually overnight), it starts and runs perfectly.
I have rebuilt the carb (Rochester 4bbl), replaced coil, spark plugs, spark plug cables, rotor & cap, fuel pump. Shop said that it was battery cables that had bad crimps, so they re-crimped everything. Said ignition was getting inconsistent electrical power as a result.
I have three thoughts - all are costly, but not sure where to start or if I am on the right track.
1. Replace Thunderbolt IV ignition amplifier - it could be overheating.
2. Replace Shift cut-out switch; not sure if that is going bad or is only affected when running at higher RPMs (over heating to make bad contacts)
3. Replace Carburetor
It also acts like vapor lock or water in the fuel. But that doesn't make sense since I ran it for about 45 min to an hour at the lower RPM without hesitation or issues.
