1990 magnum skier
mreel
need help!! I have a 1990 magnum skier that has a 305 mercruiser and velvet drive tranny! the motor is out and the coupler on flywheel will not fit my tranny splines. I have course splines on coupler and tranny has fine splines. The coupler I have is round! Does any one know where I can get correct coupler???
mreel
Re: 1990 magnum skier
ok thanks! Do you think I have correct motor? It bolted right to motor mounts! I also need a wire diagram to hook everything up?
Bt Doctur
Have no idea what you have, need some pics. to install that package you need the trans hooked to the engine first.
uses the 2 front engine mounts and the 2 trans mounts, then engine to shaft alignment has to be done.
Bt Doctur
