Hello...maybe I am just paranoid, but fired up the motor in a tub last night(getting ready for striper season), and after it idled for about 10-15 minutes the block by #4 cylider got HOT. #1 cylider is warm, then it progresses down to #4(on the bottom) being HOT, so hot that after a second you have to pull your hand away. <br /><br />There is significant water flow out the holes halfway up the leg, it is a steady stream of warm water out these holes....and when the motor is kicked into high idle for a few minutes the block by #4 cylider cools down some.<br /><br />Is this normal?? Or do I need to fix something????
