piercesmarine
- Jun 22, 2007
- 8
Re: 1990 dt115 suzuki with full throttle issues
your sneeze at idle would be idle jet not clean are lean air mixture screw try coming out with mixture screws 1 turn that would riching the idle up. normal setting for that year was about 11/2 turns out. Also the float levels on the carb should all be measured to be the same. as far as your top end miss its probably your rev limit kicking in. do you have a suzuki monitor hooked up with your oil level heat and rev light? But all in all take it back to the dude that did the work.
