Re: 1990 90hp quickstart?
Thanks for the flywheel thread.
I used a cheap steering wheel puller and a 3 foot one inch pipe.
I tightened down the puller with 3, 3 inch bolts the put the pipe under the fly wheel next to the starter applied a little pressure up and gave the opposite side a whack with a rubber hammer and it popped right off.
All took about 2 hours to get power head off and to a bench. including removing all the bolts to get the piston out. Not a pretty Piston. I have seen worse in my Skidoo, but it is still running and this makes 11 years. So I am going to give it a try.
tried to braze weld a couple of old motorcycle parts and good thing I did not try to fix these cracks this way. I will JB Weld them and if that doesn't hold up to what heat is there I will use muffler epoxy. I think as long as I clean the area real well and coat it 1/8th inch thick JB WELD on both the inside and the outside, it will hold. The stuff is not a cure all but I have repaired hydraulic pistons that have held well and didn,t leak. I also repaired a transmission case crack with no leaks. I also repaired an old ford oil pan leak. As long as it doesn't get too hot it will hold up great.
camera ran out of battery. I will put some new ones in it tomorrow and snap some shots.
I still don't know if I want to open the other two cylinders thinking if it aint broke don't fix it.
I honed for about 2 hours and the walls look and feel real smooth.
when I took the old rings off the ugly piston, the second ring was stuck real bad. I cleaned out the grooves with the old rings and gapped and installed the new ones. They were a little over sized so I used the mini hand grinder to take a little off till the gaps looked right with feeler gages.
Its late but my plans for tomorrow have been cancled to I will have a crack at it then. no pun intended.
