Jerry Baja
- Jul 26, 2017
- 2
Problem has developed in the last week. Motor starts easy, idles smooth and runs smooth at different speeds. At 3000 rpm it will run well, at 4000 rpm it will run smooth there as well. There is no loss of power bring the boat up to plane and no hesitation. But if I try to increase the speed quickly the engine will drop off and lose power boat drops off plane I pull the throttle back and the motor is still running at idle with no miss. i can put it back on plane immediately with no ill affect in power. The boat weighs 4000 lbs. The tach is not working as designed it fluctuates at times and does not read accurately at 600 to 1500 rpm. I do know that at 3000 rpm there boat does 30 mph and it is doing that so at that speed the tach is correct from past performance. I also know there is at least 3 floats loose in the gas tank. I have changed the fuel filter. Any help would be appreciated. thanks
