I'm normally a merc guy but was given a SPL 48. A straw from my fogging oil fell into the cylinder, so I removed the cylinder head (and thermostat, including the PITA plastic screw cover). Normally I would by the factory service manuals in addition to a clymer, but not trying to invest a lot in this thing.
Got the new head gasket, the sierra gasket has printed on it "DO NOT USE SEALER"
I was planning on at least using OMC gasket adhesive, should I not?
Also - torque values? For the sequence, I assume start middle bolts and work outward (up down up down)?
