Hey guys, just bought a boat literally 2 hours ago. Water tested great, fired right up, comp test was 120 even on both cylinders.
Well I was loading the boat up to leave after making the deal, and noticed blackish oil leaking from what seemed to be behind the prop, down onto the skeg and then the ground.
How hard is it to replace the seals down there "prop shaft seal"? Or is it possibly just unburned 2-stroke oil as I've read in some quick searches.
Thanks guys
Thanks guys
