Motor idles fine. When I get her out to the bay and hit the throttle the boat planes off great. I don't have a working tac, but using GPS I hit full throttle at roughly 27MPH and then the motor dies. I'm able to start right up again and plane off again, but when I hit full throttle it stalls again. Always between 25 and 27 MPH. (Capri 1700). Never any issue starting back up.
I just took apart, cleaned and rebuilt all 3 carbs. Also replaced the 3 check valves in the fuel pump as well as the diaphragm and gasket, and the reed valves looked great, so I don't think it's a fuel delivery issue. Battery was reading 13.4 volts when planed off, so I believe the stator is working fine. Has anyone ever had this problem?
Any help would be greatly appreciated. Thanks.
