camawelander
- Jun 4, 2008
- 34
Hello,
So, my TinyTach just died and I'm thinking about installing a Teleflex or similar style in dash tach.
The motor is the 1989 Force 35 - Model 357Y94 Serial 1012.
Attached is a photo of the "electrical connection strip" on my motor with the corresponding sticker that describes where each terminal goes.
It looks like there is a terminal ready for a tachometer install...purple wire.
Is the install as easy as running a wire from the back of the tach to this terminal?
And also probably run a ground wire?
Will I need to run a separate power wire, or will the tach terminal power it?
Also, any recommendations on style or type or brand that I should look at?
Is there a specific type of tach I need.
Thanks!
Thanks!
