1989 Force 15 hp - No spark
retrain
I have a 1989 Force 15 hp with no spark. I have checked everything I can think of and it seems to check out. Any ideas what could be causing this problem? Any help would be greatly appreciated!!!!!!!
fishrdan
Re: 1989 Force 15 hp
Is the safety lanyard attached or motor kills switch shorted out?
The BIM coils can go bad, causing no spark.
retrain
Thanks for the quick reply. Lanyard is attached and the kill switch tested good. Can you test the coils for continuity to see if they are bad?
jerryjerry05
What's the serial#.Post a pic.
Maybe the flywheel key has sheared.
Try outboardignition.com has test procedures.It might help.J
bentle
Re: 1989 Force 15 hp - No spark
Did you do a spark test on each cylinder? Im asking because it is really easy to flood these little
motors and when the plugs get soaked with fuel mix it will not start until you pull the plugs and clean & dry them.
retrain
Thanks for both the replies. The flywheel key is still there but I don't have the serial number since I am at work. I spark tested both spark plugs and both were dead. I will try the link and see if it helps.
