1989 DT8 suzuki wont idle
Victor Erickson
Have trouble with engine idling when trolling. Have to have choke on to stay ideling while trolling. then engine just dies and have to choke to start. took carb apart and cleaned it with spray cleaner through jets runs worse. Also how many turns do you need to turn the air screw to adjust carb?
deejaycee_2000
Re: 1989 DT8 suzuki wont idle
Did you do a proper carb rebuild? Soak in carb cleaner over night and blow out with compressed air? ... the correct setting is 1 & 1/2 turns outwards from soft stop ....
Victor Erickson
we did not soak overnight.But have cleaned the jets. not needle and seat. The carb does seem clean.. we have tried setting the air/fuel ration to 1 and1/2 but will not idle at low when reveved up some will run but as soon as we go to low idle it quits. it will run at 3 turns but when in gear will not run at lower idle. it has us stumped.
Thanks for your reply any othe suggestions..
99yam40
do a better job of cleaning the carbs
Should run properly at the spec setting if carbs are clean
deejaycee_2000
I agree, you have to do a proper clean because it might look clean but it might not be (I have made this mistake too many times in my younger days) ..... also check your fuel pump diaphram ...
