DudeAbides
- Jun 20, 2015
- 54
Hello All. I am the proud new owner of an old 89 16' bayliner with its original 85HP Force.
I have read through a lot of the previous posts over the last 2 weeks and feel very lucky to have found this forum.
Thank you to all who contribute their time and knowledge here.
The issue I have been chasing is a rough idle and difficulty starting cold. Once I am in gear and opening up the throttle it seems to operate better.
I have gone through and cleaned the carbs (there was what appeared to be tiny bits of fuel hose in the bowls)
I am running fresh clean gas, my choke works well, timing is good.
So I am now replacing all the original fuel lines including the recirc. lines
Does anyone have any guidance for cleaning the rest of the recirc system? my seloc manual shows the line routings and fittings but it is clearly not my model.
Should the cylinder reed drain cover come off?
It appears that all of my barb fittings are just open pathways except for the lowest one that comes off the manifold by the carb. This one appears to be a metering device and was completely blocked and had tons of junk in the hose.
So if anyone has gone through theirs and can offer any guidance I would appreciate it.
Thanks
Jason
Thanks
Jason
