No Title
YIPPIE, wahoo... and all that other stuff.. .no more oil leaking!!!!
During my test though... sad sad moments too. Motor was running smooth, temp right around 175, oil pressure at about 45psi, all seemed good, then it had a hiccup of sorts... a rattle. so I throttled it down from 3200 to idle and it stalled?? Okay maybe.. my down throttle was a knee jerk response to the rattle - I'll give it that. Went to restart it and it it was hard to start.... like suddenly I had 13:1 compression or something. It did kick off after a 3 or 4 revolutions... but that rattle was still there??? temp was still 175-ish, but it had crap for oil pressure... around 8psi? So I shut it down.. checked oil - level still good. opened the oil fill cap and had smoke of some kind of smoke (didn't smell, so heavy steam maybe?) coming out of the valve cover. I guess it's time to pull the plugs and do another compression check :-(
Honestly though - I put the cover over it and just walked away.... I don't know how much more of this I can really take!!! I fix one thing, then another thing goes wrong... each step seems to be getting worse and worse.
I go back to work on Monday and also filled with trying to spend some time with my grandmother before the inevitable... just not in the bloody mood to start over on the boat AGAIN! But on a good note.... the oil leak is fixed.
