Re: 1989 35hp Force: Can't shut off
On the back of the ignition switch there should be 2 terminals labeled with the letter "m".<br /><br />A blue wire from the wiring harness and a blue wire from the kill switch should be attached to one of the "m" terminals.<br /><br />A white wire from the wiring harness and a white wire from the kill switch should be attached to the other "m" terminal.<br /><br />Connecting the blue and white by tripping the kill switch, or connecting the blue and white by turning the ignition key to off, will ground out the ignition and stop the motor.
