boatflipper
- Jun 16, 2009
- 500
I purchased a 1988 sea ray 230 weekender that sat for roughly 2 years. It is equipped with a 7.4L Mercruiser and alpha one ourdrive. (Bad engine for this boat bc of the strain it puts on outdrive-i know). Before it was parked the carb was rebuilt and I have the documentation for that. (Unforseen circumstances with the previous owner caused it to sit for the 2 year period.) it has a 70 gallon gas tank which had about 10-20 gallons of gas which he said he treated with fuel stabilizer and I proceeded to fill it up with premium fuel and additional fuel treatment. Boat starts and idles great, but at 2000-2500 rpm range it will idle way down and if you don't pull the throttle back it will stall completely and sometimes back fire. I have replaced the fuel filter, looked at the inlet valve at the fuel tank, and replaced the distributor cap and rotor button. Still doing it. I've head it's the carb and I've heard it's the fuel pump. Any other ideas? Thanks in advance!
