Re: 1988 or 89 Suzuki DT175; opinions?
I too had a 1989 DT-200, which is the same engine with slightly larger carbs, and ran it up until last fall - at which time it was still running strong. Mine has slightly over 2,000 hours on the meter when I sold it and is still running strong on a 20-foot Mako down in the Keys. In the years I owned the engine my total cost for parts and maintaninece, including annual water pump replacements, was less than $1,000. Parts availability might be a bit of a problem, but of course there is always Brown's Point, but for us it never was because in the entire time I had the engine the only parts I ever had to replace were a throtle position sensor and a fuel enrichment valve. The fuel enrichment valve had been bad since the day I bought the engine, but I didn't know it until about year 4 or so. So if you ask me its the most reliable engine on the market. As for economy, well, there isn't any large V-6 that anyone would call economical. My maximum burn rate was just under 20 gallons per hour, at trolling speeds it sucked down gas at 3~4 GPH. I used to cruise at about 4,200 RPM and it would burn right at 12~14 GPH in that area. The 175 should burn just a bit less and of course if your boat is lighter than mine (23' walkaround at about 6,000 pounds fully loaded) it will get better economy as well.<br /><br />Good engines in my my opnion. Oh, I sold mine for $900 with controls, guages, cables, and a stainless prop. I knew the guy who bought it or I would have asked (firm) around $1,200 for it.<br /><br />Thom
