When I start my motor the idle will be high. I adjusted the idle cable at the engine so the stop bolt is bottomed on the cam. If I rev the throttle or put in gear and go fast when I go back to neutral it will be idiling high again. If I pull off the engine cover and push the cam back down it will sometimes stay in the stop position and aidle fine, other times it will not stay in the slow idle but close and only idle a little high. Is there adjustments on the throttle control side that will fix this? I know the set screw for the idle has never been touched on the motor.
Second queston how do I remove the shifter handle on the control? Its very loose and needs to be tighned up.
Any hints would be helpful.
Thanks
Thanks
