1988 90hp mercury oil injection
rp75951
I have a 1988 mercury 90hp outboard with oil injection, is it better to let motor mix oil or should I disconnect and mix myself?
If better to mix myself how do I disconnect oil injection? Also where can I get a service manual for this unit?
TD_Maker
Re: 1988 90hp mercury oil injection
Carholme is on this. I bow before the Guru. Do what he says.
Faztbullet
The 3 cylinder 75-90hp have a bottom driven oil pump that rarely fails( only seen 2 ) , most of the problems is false alarm from magnet in tank falling off or bad sensor or module. I myself say leave it alone.....JMO
