horiconducker
- May 12, 2008
- 96
Do a linc and sync is it timed right there is a low speed timing for that motor. What is the high speed jet number in the carbs you have. It sounds like your motor runs rich at an idle and clears up as you accelerate.
Ive done the lync and sync per the oem manual. There is a method A (has a throttle pickup timing spec) and a method B ( which is completely different and has no throttle pickup timing spec). My motor uses method B due to the throttle cam it has. Ive tried adjusting the motor to let it have a little more timing before throttle plates open but it runs worse. Runs best set to the factory manual specs for method B. I don't remember the jet numbers off hand, but when I rebuilt the adjustable carbs before i put them on, i checked the jets and they were correct for the 91.
