bassangler1027
- Sep 27, 2012
- 8
I have a 1988 200hp merc and it is running rich . and it is loading up when takeing off but then cleaning out and running great WOT ( 5400 rpms) here is what i have done to try and correct the problem
first replaced plugs and wires , cleaned carbs and new gaskits , when cleaning there were little pick up tubes goes to bowl to mixing chamber that were pluged up, rebult fuel pump and it got alot better but still loading up ( wet plugs) but not as bad
so today I checked timing ( by the manuel) and it is in time , LINKED and SYNC it is all good
checked stator, trigger and coils they all check good
checked compression ( 130-128 lbs on all six)
replaced fuel lines but not primer cause it gets hard when primeing but it is pointing down so check valve is staying foward not sure if i need to reposition it .
and also i did not check the floats adjustment and I was wondering if the are letting to much fuel in bowls if this would cause it to load up , I am thinking it would but just need some pointers thanks alot
also it has a 13 7\8 23 pitch prop but according to the prop guys thats right for this boat and weight 21 foot stratos 1990
