phatmanmike
- Oct 24, 2003
- 3,869
its actually a 14hp. 1988 . motor wont pee.
if i remove the thermostat and leave the thermo cover off, water pumps outa the thermo housing. water also comes outa the exhaust ports too( i run it in a bucket, not on muffs) so i know its "pumping" water.
with the thermostat in, i get a lite dribble outa the pee tube, and i get a normal looking amount from the exhaust ports.
with the thermostat removed and the cover put back on, i get an over abundance of water from the exhaust relief ports. LOTS of water, a very strong spray at idle.
any ideas? does this mean h20 pump is dead or thermo needs replaced. i tried running wire in the pee tube, no change.
could it be that the thermo is old and stopping water flow? it doesnt over heat, i can touch the motor on all sides and it isnt overly hot. this is the first time ive ran it in a few months, and last time i ran it it peed after just a few seconds or soo.
i tried cleaning the thermo, its atleast 3 years old, thats how long ive had the motor.
