1987 sportcraft ski king 160
obie130
Hi, I have a sportcraft ski king 160 I'm new to boating when I bought it she had no fuel in the built in tank after I filled the tank you can smell gas fumes very strong id like to run new fuel lines to see if that will remedy the problem is there any way to get to the fuel tank without having to pull the floor out the floor and carpet is new I did not want to mess it all up thanks allot
Bt Doctur
Re: 1987 sportcraft ski king 160
Could be the lines BUT I doubt if. there should be pop lids to access the hose connections.I`d cap them and apply about 3 pounds air pressure and see if it holds.most use a hatch cover system . Without it the carpet comes up and your saw gets used.
