Also, as someone mentioned in your other post, you need to run this motor on 50/1 gas oil mixture, not 100/1 like the little sticker says. In fact if that sticker is still on the motor, it would be a good idea to remove it.
Thanks. I did mix 50 to 1 ratio with marine grade oil. The motor runs perfect now. Thanks to you explained the proper cold start procedure. I just cranked it a few mins ago with one pull. After it sat for 6 hours and I didn't even pull the primer/ choke. Awesome.
