Model E50TLCUD, low hours (less than 100). VRO has been bypassed. Runs about 3 times a year. We took it out Monday ran a wot for at least 20 min, it cut out a couple of times after hitting some rough water. It idles rough now.
Checked fuel output from the pump while cranking...good
Sprayed carb cleaner in both carbs while running....upper carb, little change, lower carb moter dies.
Both plugs have the correct gap and are firing.
Thinking about ordering carb kits for both, and stabil in the gas from now on.
Anything else could be wrong here?
Thanks for any help.
Chris
Chris
