1986 searay seville fuel gauge not working
skipbehr
I have a 1986 searay seville just purchased and the fuel gauge is not working . Seems to be hooked up , Where to start looking thanks
Silvertip
Re: 1986 searay seville fuel gauge not working
Check the "stickies" for "Fuel Gauge Troubleshooting".
skipbehr
OK : I found the problem. I removed the floor panel after trouble shooting with a meter. The positive wire terminal had been pushed down and shorted out and coroded there (green). I put a new connector on the wire cleaned up the terminal and glued two pieces of 3/4 inch plywood to the tank on either side of fuel gauge to keep the floor panel from crushing the connector. everything is in order and working. Thanks for any help.
NYBo
You should fix that panel so you aren't supporting weight with the fuel tank.
