Zq8 Blazer
- Mar 18, 2012
- 48
okay now that my ignition troubles are solved and I'm getting spark (btw the middle cylinder isn't sparking, but I'm thinking that's just a bad coil.). The engine isn't getting any gas. Both carbs have gas in their bowls, but none is getting out. I took both carbs out and cleaned the jets then sprayed them down with carb cleaner. Reinstalled and same thing, gas in the bowls, but none comes out the jets.
I also sprayed starting fluid into the carbs while trying to start the engine and it didn't try to run.
